Lift Blocks
Guest Riggs
Im thinking about getting 2 inch pro comp lift blocks for the rear and cranking the torsion bars a little more for some more lift. im trying to fit 37's under the truck. does anybody have 37's on there truck? or lift blocks?
what do you think?
Lift blocks are a bad idea and over cranking your torsion bars is an even worse idea. The blocks can cause axle twist and since your already sittin' high off the ground you'll deffinatley notice that and over cranking your torsion bars puts alot of stress on your front end.
And 37's are too big for the 1/2 ton IFS to handle. They will wreak havoc on all your front end components, especially with a torsion crank. Just stick with 35's, and you'll be a lot safer.
yeah ot too good an idea. If you want alot of lift like that get a whole suspension lift kit, & 35s would probably be the max you could run.
alright. im thinking about either 35/36x12.50/13.50/15 TSL Radials
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
