Speaker Issues
My speaker is blown and i'm not sure whether to try to fix it myself or take it to the dealer. Any tips on door panel removal?
Any help would be appreciated,
Thanks
Thanks
YMM and BS? (Year Make Model and Body Style - Regular, Extended, Crew) and location of blown speaker?
If it is the front door, removal of the panels is really easy. you pop off the mirror cover, power door lock cover, and the actual door lock trim, and tehre is one screw where the power door lock switch is, there is one under the handle, and one on the way bottom of the door. Once everything is off, you slide the whole panel up like a inch (not even), and it will come out. There is a lightbulb for the door marker lights that you will have to pull off before setting the panel somewhere, but the speaker is easy for a DIY repair.
Thanks
It's a 2001 chev silverado Z71 extended cab 1500 and the speaker is passenger side door.
ask and you shall receive and dont try to use the magnfying glass cause it wont work at all:
Front Side Door Trim Panel Replacement
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=782992&pubid=210&evc=sm&cellId=11499#ss1-782992">
Removal Procedure
  1. <LI type=1>Remove the door handle bezel. Refer to
Door Handle Bezel Replacement . <LI type=1>Remove the window handle, if equipped. Refer to Door Window Regulator Handle Replacement . <LI type=1>Remove the power accessory switch panel. Refer to Power Accessory Switch Panel Replacement . <LI type=1>Remove the trim panel upper extension. Refer to Trim Panel Replacement - Upper Extension . <LI type=1>Remove the trim panel screws.
<LI type=1>Remove the courtesy light, if equipped. Refer to Door Courtesy Lamp and Reflector Replacement . <LI type=1>Remove door panel screws. <LI type=1>Remove the trim panel from the door, carefully sliding the trim panel up to release the retainers from the door.
Remove the speaker wire.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=782992&pubid=210&evc=sm&cellId=11499#ss2-782992">
Installation Procedure
    <LI type=1>Install the speaker wire. <LI type=1>Install the courtesy light, if equipped. Refer to
Door Courtesy Lamp and Reflector Replacement . <LI type=1>Install the trim panel to the door by carefully aligning and sliding the panel down into the retainer slots. <LI type=1>Install the window handle, if equipped. Refer to Door Window Regulator Handle Replacement . <LI type=1>Install the power accessory switch panel. Refer to Power Accessory Switch Panel Replacement . Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
<LI type=1>Install the trim panel screws. Tighten
Tighten the trim panel armrest screws to 2 N·m (18 lb in).
<LI type=1>Install the trim panel upper extension. Refer to Trim Panel Replacement - Upper Extension .
Install the door handle bezel. Refer to Door Handle Bezel Replacement .
Thanks man i really appreciate it.
Document ID# 536768
2001 Chevrolet Chevy K Silverado - 4WD
Door Handle Bezel Replacement (Inside Front)
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=536768&pubid=210&cellid=11304&evc=sm#ss1-536768">
Removal Procedure
  1. <LI type=1>Insert a flat-bladed tool between the door handle bezel and the trim panel in order to release the door handle bezel tab retainers.
  2. Remove the door handle bezel from the door panel.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=536768&pubid=210&cellid=11304&evc=sm#ss2-536768">
    <LI type=1>Position the door handle bezel into place in the door trim panel.
  2. Install the door handle bezel to the door panel, pressing the bezel into place until fully seated.
Document ID# 536768
Document ID# 536775
Upper Extension Trim Panel Replacement
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=536775&pubid=210&evc=sm&cellId=11655#ss1-536775">
Removal Procedure
  1. <LI type=1>Open the front door.
    <LI type=1>Release the upper extension by pulling outward on the front edge in order to release the upper retainer clips.
  2. Remove the upper extension from the trim panel by lifting up and out.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=536775&pubid=210&evc=sm&cellId=11655#ss2-536775">
    <LI type=1>Position the lower retainer to the trim panel. <LI type=1>Align the upper retainer clips to the door frame.
  2. Press inward on the upper extension until the clips fully engage securing the panel to the door.
Document ID# 536775
Document ID# 731973
Radio Front Side Door Speaker Replacement
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=731973&pubid=210&evc=sm&cellId=46937#ss1-731973">
Removal Procedure
  1. <LI type=1>Remove the trim panel. Refer to
Front Side Door Trim Panel Replacement in Doors.
<LI type=1>Remove the speaker by pushing down on the top retainer.
Disconnect the electrical connector.
<A href="http://service.gm.com/servlets/BlobShtml?ShtmlFile=731973&pubid=210&evc=sm&cellId=46937#ss2-731973">
    <LI type=1>Connect the electrical connector. <LI type=1>Install the speaker. Snap the speaker into place and ensure that the speaker is fully seated.
    <LI type=1>Install the trim panel. Refer to
Inspect the component's operation.
Document ID# 731973
sorry everytime I post diagrams, I seem to hit the max character limit resulting in multiple posts, enjoy......as you can see Jeff knows his stuff..............
Can i replace it with any speaker or do i need to order one from chev?
Yes he does, thanks
I blew mine and got pioneers at walmart for 40 bucks, sound way better, to some soldering the new connectors and drilling the holes in the door might be hard though.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 937 Guests (See full list)
