Obd Ii Connection Not Working
bamdoo
I have a 2003 Envoy and the SES light came on. I tried using my OBD II scanner but it doesn't turn on when I plug it into the vehicle. I have used the scanner on my car before with no problems. I tested it on my wifes car and it worked fine. What could be causing the problem? Could it be the same problem that made the SES light come on? Your advice would be greatly appreciated.
Thanks,
Rob
Are you sure your scanner is compatible? I know there are year breaks where a newer type of scanner is required. My Matco scanner won't work on an 06 model. Not sure how far up it goes... Anybody know?
I'm not sure about aftermarket scanners and what you'll need presently and in the future but GM's communication architecture changed to CAN in 06. Anything 06 to present in the shop needs a CANdi module inbetween vehicle and t-2. Starting in 09 we will not be using the t-2 anymore but the new MDI module that will communicate with everything but there is no screen on the thing its a pass through to pc tool.
Sorry to keep bumping but what model is your scanner?
Excellent call on that fuse.
I don't know what model it is but I will get a look at it and let you know. I would like to update it to work with newer models.
Thanks the very last pin is the B+ and usually powered by the lighter. With all the stuff we plug into them nowadays their always blown.
All I was going to do is search the Matco site for an adapter but you can go there and see if you find one if not get me that model # and I'll see what I can find for you.
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
