Loose Steering With My 2500hd
I have a 2006 2500HD Duramax 3/4ton shortbed, I’m have abnormal issues with the steering in 2 & 4 wheel drive on slippery or snowing conditions. The issues are when I accelerate the steering feels loose and has play when steering, it feels like the front end is light or something. The only thing I’ve done to the front end is turn the torsion bar bolts a little to level out the look of the truck. It’s a spooky feeling, any suggestions?
Just a front end alignment, do I need to change the Torsion bars back at all?
By changing the torsion bars, you have altered your front end alignment.
You need to get it realigned ASAP.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
