Gear Swap And Abs/computer Programming
Has anyone had any adverse effects from the ABS or Computer programming when swapping gears?
I have an 07 2500HD NBS with the 6 speed automatic transmission and plan to install a 4" lift with 33" tall tires. Currently it has 3.73 gears, if I swap gears to 4.10's and install the 33" tires, the end ratio will be the same as the 3.73's.
I don't plan to update the computer for the tire size and/or gears.
Will I have any ABS or Computer problems?
