Auto Headlamps Won’t Turn Off
norsemanberg
I can’t turn off my auto headlamps. I bought my 2003 GMC Sierra used from a used truck dealer and I think it acme from Canada and I think that since it was originally sold in Canada turning off the auto headlamps wasn’t an option for them. Is there a way I can change it back so I can turn off the auto headlamps?
Document ID# 1555524
2003 GMC Truck GMC K Sierra - 4WD
Subject: 03-05 Cadillac/Chevrolet/GMC Full Size Trucks and Utilities DRLs Will Not Disable with Headlamp Switch - kw automatic head inoperative lamp light switch DRL #PIT3219 - (10/13/2004)
Models: .
The following diagnosis might be helpful if the vehicle exhibits the symptom described in the PI.
Condition/Concern:
Some customer may state that the Daytime Running Lamps (DRLs) or the auto headlamps will not shut off when using the daytime running lamp disable switch (Which is part of the headlamp switch). Vehicles that were built in Canada and have RPO option (U19) were built with different software that does not allow the DRLs or Auto headlamp to be shut off. Canada law prohibits disabling daytime running lamps or auto headlamps.
Recommendation/Instructions:
This is a normal operation of the vehicle and no repairs should be attempted.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance.
Models:
(2003-2005 Full Size Trucks and Utilities)
Models: .
Condition/Concern:
Models:
So is there nothing i can do to change this? I live in wisconsin it isn't illegal here.
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
    • Yes, I connected it to my home wifi.
