I've Got The Speakers, Amps, And Hu...now What?
As I figured I would do this install myself, I bought all the parts I needed. Now I am thinking that maybe it's a bit too much for me to do. Don't get me wrong. I know how to use a multimeter, and I know how to handle the airbags. I just think I won't have the time or the space to do the job right. For example, I have 3 rolls of Damplifier Pro and a few rolls of Ensolite, but I can't install them as I don't have the room.
Can anyone recommend an installer in the Tri-State area? They've got to be as meticulous as I am. I realize that the install I want is going to run upwards of $1,000, but I want the money to be well spent. I have gone into a few shops in Brooklyn and Staten Island and I was not impressed.
Has anyone used a pro installer they would hands-down recommend?
good plan, they took 8 hours to do just my amp today. They know how picky I am at this place, they have been doing my work for years, and the manager told me all that was involved, quite a chore.
I am a tech too, and work an all types of engine electronics on HD trucks, etc, but there are 2 things I have no patience for: bodywork and stereo work on modern cars!
Anyhow, I think you made the right decision, don't feel bad about not tackling it!
My problem is I cannot seem to find anyone that will do the job the way I want done. I've gone into a few places I have done business with and told them what I wanted and I got a lot of "sure"'s and yes. One place I got a quote, $1,200 and told him I'd give him half up front and another $800 once it was done. That's $200 more. He wouldn't go for it. d**n people have become so f-in difficult to deal with.
  • 4 weeks later...
hello,
what is it that u want done exactly that the shops wont do for u?
i do installs out of my house. i have a 2001 Tahoe that i am working on now with 9 tv's and a insane stereo all custom and clean. i have done many vehicles, i am in Staten Island, if u would like to come and see my truck.
B
Uh......... yeah.
Thanks for the offer, but I'll pass. Aside from my needing to be out of my mind, had it installed by a shop a buddy referred me to. All good, and they are always there to adjust/answer questions. And, yes, they were not cheap, but they did it the way I would have. And they did it with me over their shoulder (and they charged me for my being a PITA). Where were you MECP certified?
no problem, just wanted to help.
i am mecp certified, and having been working on stereos professionally for close to 13 years.
i built a nice reputation for my self so i decided to stop working for shops and work for my self....this way i get 100% of my install pay as well as the items i sell......rather that making a shop owner rich off of my talents, u know?
i have a 4 car garage that i work out of. it is basically a shop but no store front.
Hey... Some of the best custom install artists are the ones that work on their own turf and at their own pace. You really should think about posting some pics of your work here. We'd all like to see (and probably use some of your ideas). :M16:
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 545 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
