Heart Transplant
Cheyenne
First post.......and I'll make it good. I have a '72 C10 Cheyenne that has been in the family since it was new. Grampa bought it, dad and I inherited it. The engine (402) has been rebuilt once, 1982 (I think)........ANYWAY..... I've got a nearly new 2007 LQ4/4l80e from an Express van, the PCM, harness etc. It has the fly by wire throttle body, but no pedal or TAC. I was going to junk the electronics and go with a cable operated throttle, but......What would I need to keep the electronics and could I add cruise control??? Checked with the local dealer. I can get the pedal assembly for $80. I didn't know I needed the TAC at the time. A mechanic at the dealership was good enough to give me the pin out for the PCM which helped alot. What I really need is the wiring diagram for the TAC/fly by wire system. Actually, any and all wiring diagrams for the Express would probably be helpful.....Thank in advance
I would buy a standalone computer to control the 4L80-E and a stand alone fuel injection system for the engine since I do have a 1972 Chevy in my back yard. ; ) Also I would Junk the whole factory intake and install a after market one with a cable accel. pedal. I think this would be easier and get wayyy better results than trying a shoehorned 2007 Van wiring system in the old 72 chassis. Look in the GM Performance parts catalog for your stand alone needs and parts. They have warranties. Have fun with your 72.
PS. Too bad that old 402 big block is a much better performance engine than that 6.0L. You can get 500 HP easy with a 402. Stick with the 4L80-E, built to handle power, but rebuild that 402 with fuel injection.
    • These show the problem and symptoms, and I explain things too. to clarify again, I did not change over any computers or wiring (with the exception of the map sensor). All of the computers and wiring are original to the 2010 vehicle   video 1 - background info/explanation and part of the problem   video 2, idle misfire   I think the reason that the MAP sensor is reading High is because the engine is misfiring so there is less vacuum...   Additionally there's a p0102 for the MAF low frequency, and a p0108 for the map high voltage.        Again, apologies for the somewhat long-winded explanation, it's a rather difficult problem to explain without going into the details.
    • You'd want the Pulsar to be safe.  That was the first product that worked for 10 speed trucks that they came out with.   Range Technology 22451 Pulsar LT for 2019-2022 GM Gas Trucks     That said, in the features description of the RA003B, it does list it working with 10 speeds.  However there are reports that the RA003B can cause some drivability issues on early 10 speeds.  So the Pulsar is the safest move IMO.      Range Technology RA003B AFM/DFM Disabler   Features: Range AFM/DFM Disabler keeps you in full power 100% of the time Simply plug into your onboard OBD-II port and it instantly begins working to eliminate the AFM system Disables Auto Start/Stop Blue LEDs The Range AFM/DFM Disabler does not reprogram factory ECU Works in hundreds of applications, 2007-2022, including 10-speed models. Leaves no trace, unplug it to return to factory settings Virtually no battery draw Fits all V6 and V8 General Motors (GM) active or dynamic fuel management vehicles, includes cars, trucks, and SUVs This device does not support the 2022.5+ Refresh model trucks or 2021+ SUVs To confirm your 2022 model truck is compatible with this unit, check your VIN. The 12th digit in an early model must be a '4' or lower Made in USA
    • I have a 2019 new body style high country with a 6.2l L87 and a 10 speed transmission code MQB. Looking for a disabler that is compatible. Most show it’s not. I watched a video on utube from Dons Life that says Ranges RA003B is compatible but when you go to Ranges website and check compatibility it only has a 8L90 trans listed which is an 8 speed.  I don’t want to buy the wrong one. Anyone have any experience with this situation?
    • This actually happened. Be careful where you get your information re: gas price trends.
    • I understand the principle...you don't want to spend $150 for a $0.02 piece of plastic or a little screw and perch thingy.   But this is a problem that looks like it can be reliably solved with a zip tie.   That might hold you over until you can score one at a pick-a-parts yard.
