Intermitten Crank No Start
babydirt
I have a 02 GMC sierra that will somtimes not start.
I have checked for fuel at the rail and I do have fuel.
I have spark checked with a inline spark tester spark seems to be strong but does not seem to pulse at the same rate continually when cranking.
Checked for faults no faults stored
Once car starts it may miss a little when starting but after that runs fine
and has plenty of power
You will need to do a fuel pressure check. With the fuel gauge connected, you will need to record fuel pressure with key on engine off, fuel pressure with engine running, and fuel pressure drop after truck is off.
Or
One other way is to when you get ready to start it after sitting for a while turn the key to the on position then back off. Do this 5 times. On the 5th time start it. If it starts right up good if not then let me know. Over the next few days do the same thing. If it starts up every time then your problem is fuel pressure related.
Or
Thanks,
I'll do a fuel pressure test tomarrow do you know what the specs are? If yes can you give them to me
I did depress the shrader valve while cranking the engine it seemed that i had plenty of fuel. It was spraying out pretty good.
Fuel System Diagnosis
System Description
When you turn ON the ignition switch, the control module enables the fuel pump relay which powers the fuel pump ON. The fuel pump remains ON as long as the engine is cranking or running and the control module receives ignition reference pulses. If there are no ignition reference pulses, the control module shuts the fuel pump OFF within 2 seconds after the ignition was switched to the ON position or if the engine stops.
The fuel tank stores the fuel supply. The electric fuel pump supplies fuel through an in-line fuel filter to the fuel injection system. The pump provides fuel at a higher rate of flow than is needed by the fuel injection system. The fuel pressure regulator maintains the correct fuel pressure to the fuel injection system. A separate pipe returns unused fuel to the fuel tank.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This step verifies that the fuel pump is operating.
This step tests for an internal fuel leak. If the fuel pressure drops during this test, then an internal loss of pressure is indicated.
This step tests the fuel pressure regulator. The fuel pressure regulator is controlled by the engine vacuum. With the engine vacuum applied, the pressure should drop to the specified value.
This step inspects the fuel pressure regulator for a fuel leak from the vacuum port. If fuel leaks from the fuel pressure regulator while the fuel pump is commanded ON, replace the fuel pressure regulator.
This step tests for a loss of fuel pressure between the fuel feed pipe shut-off adapter and the fuel pump.
This step tests for a leaking fuel injector or for a leaking fuel pressure regulator. If the fuel pressure remains constant during this test, the fuel injectors are not leaking fuel.
This step tests for a restricted fuel return pipe. If the fuel pressure is within the specified values, there is a restriction in the fuel return pipe.
This step determines if the fuel pressure regulator or the fuel pump is the cause of the low fuel pressure. If the pressure rises above the specified value, the fuel pump is OK.
This step verifies that a circuit condition is not the cause of a fuel pressure concern. Thoroughly inspect all fuel electrical circuits.
Fuel System Diagnosis Step
Action
Values
Yes
No
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
Important: Before you proceed with this diagnostic, inspect the fuel system for damage and for external leaks.
Turn ON the ignition. with the engine OFF.
Command the fuel ON pump with a scan tool.
Does the fuel pump operate?
Go to Step 3
Go to Intermittent Conditions
3
Turn OFF the ignition.
Turn OFF all accessories.
Caution: Wrap a shop towel around the fuel pressure connection in order to reduce the risk of fire and personal injury. The towel will absorb any fuel leakage that occurs during the connection of the fuel pressure gage. Place the towel in an approved container when the connection of the fuel pressure gage is complete.
Install the J 34730-1A Fuel Pressure Gauge.
Place the bleed house from the fuel pressure gage into an approved gasoline container.
Turn ON the ignition, with the engine OFF.
Command the fuel pump ON with a scan tool.
Bleed the air from the fuel pressure gage.
Important:
• You may need to command the fuel pump ON several times, in order to obtain the highest possible fuel pressure.
• Do NOT start the engine.
Command the fuel pump ON with a scan tool, and observe the fuel pressure gage.
Is the fuel pressure within the specified value?
385-425 kPa
(55-62 psi) VIN: (V, T,U)
335-375 (48-54 psi) VIN: Z
Go to Step 4
Go to Step 12
4
Important: The fuel pressure may vary slightly when the fuel pump stops operating. After the fuel pump stops operating, the fuel pressure should stabilize, then remain constant.
Monitor the fuel pressure gage for 1 minute.
Does the fuel pressure drop more than the specified value?
34 kPa
(5 psi)
Go to Step 9
Go to Step 5
5
Relieve the fuel pressure to the first specified value.
Does the fuel pressure drop more than the second specified value?
69 kPa
(10 psi)
14 kPa
(2 psi)
Go to Step 24
Go to Step 6
6
Turn OFF the ignition for 15 seconds.
Monitor the fuel pressure gage.
Start the engine.
Does the fuel pressure drop the specified value when the engine is started?
21-69 kPa
(3-10 psi)
Go to Step 7
Go to Step 8
7
Operate the vehicle within the conditions of the customer's concerns.
Monitor the fuel-related parameters with a scan tool.
Do any of the scan tool parameters indicate a lean condition?
Go to Step 17
Go to Symptoms - Engine Controls
8
Disconnect the vacuum hose from the fuel pressure regulator.
Idle the engine.
Apply 12-14 inches of vacuum to the fuel pressure regulator with a hand-held vacuum pump.
Does the fuel pressure drop the specified value when the vacuum is applied?
21-69 kPa (3-10 psi)
Go to Step 21
Go to Step 23
9
Remove the vacuum hose from the fuel pressure regulator.
Inspect for a fuel leak from the vacuum port of the fuel pressure regulator .
Is the fuel pressure regulator leaking fuel?
Go to Step 23
Go to Step 10
10
Relieve the fuel pressure. Refer to Fuel Pressure Relief Procedure .
Disconnect the fuel feed hose and the fuel return hose from the fuel rail. Refer to Quick Connect Fitting(s) Service (Metal Collar) .
Install the J 37287 Shut-Off Adapters between the fuel hoses and the fuel rail pipes.
Open the valves on the fuel pipe shut-off adapters.
Command the fuel pump ON, then OFF with a scan tool.
Close the fuel feed pipe shut-off valve.
Does the fuel pressure remain constant?
Go to Step 19
Go to Step 11
11
Open the shut-off valve for the fuel feed pipe.
Close the shut-off valve for the fuel return pipe.
Go to Step 23
Go to Step 20
12
Is the fuel pressure more than the specified value?
427 kPa (62 psi) VIN: (V, T,U)
375 KPa (54 psi) VIN: Z
Go to Step 14
Go to Step 13
13
0 kPa (0 psi)
Go to Step 16
Go to Step 17
14
Disconnect the fuel return hose from the fuel rail return pipe. Refer to Quick Connect Fitting(s) Service (Metal Collar) .
Attach a length of flexible fuel hose to the fuel rail outlet passage.
Place the open end of the flexible fuel hose into an approved gasoline container.
Monitor the fuel pressure gage with the fuel pump operating.
385-425 kPa (55-62 psi) VIN: (V, T,U)
335-375 KPa (48-54 psi) VIN: Z
Go to Step 22
Go to Step 15
15
Inspect the fuel rail outlet passage for a restriction.
Did you find and correct the condition?
Go to Step 25
Go to Step 23
16
Install the J 37287 between the fuel return pipe and the fuel rail.
Open the valve on the fuel pipe shut-off adapter.
Use a scan tool in order to command the fuel pump ON.
Bleed the air from the fuel system.
Notice: DO NOT allow the fuel pressure to exceed 517 kPa (75 psi). Excessive pressure may damage the fuel system.
Slowly close the valve in the fuel pipe shut-off adapter.
Does the fuel pressure rise above the specified value?
425 kPa (62 psi) VIN: (V, T,U)
Go to Step 23
Go to Step 17
17
Inspect the following components for restrictions:
• The fuel filter
• The fuel feed pipe
Go to Step 25
Go to Step 18
18
Inspect the harness connectors and the ground circuits of the fuel pump for bad connections. Refer to Testing for Intermittent Conditions and Poor Connections , and refer to Connector Repairs in Wiring Systems.
Go to Step 25
Go to Step 19
19
Remove the fuel sender assembly. Refer to Fuel Sender Assembly Replacement .
Inspect the following components:
- The fuel pump flex hose for damage
- The in-tank fuel pump harness connectors for bad connections
- The fuel strainer for restrictions
- The fuel tank for contaminants
Did you find and correct any conditions?
Go to Step 25
Go to Step 24
20
Raise the fuel rail, with the fuel lines connected. Refer to Fuel Rail Assembly Replacement .
Locate the replace the leaking fuel injector Refer to Fuel Injector Replacement .
Did you complete the replacement?
Go to Step 25
21
Repair the vacuum source to the fuel pressure regulator.
Did you complete the repair?
Go to Step 25
22
Locate and repair the restricted fuel return line.
Go to Step 25
23
Important: Before your replace the fuel pressure regulator, inspect for a missing or damaged fuel pressure regulator O-ring seal.
Replace the fuel pressure regulator. Refer to Fuel Pressure Regulator Replacement .
Go to Step 25
24
Replace the fuel pump. Refer to Fuel Sender Assembly Replacement .
Go to Step 25
25
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
System Description
Test Description
Action
Values
Yes
No
Go to Step 2
2
Go to Step 3
3
Important:
385-425 kPa
Go to Step 4
Go to Step 12
4
34 kPa
(5 psi)
Go to Step 9
Go to Step 5
5
69 kPa
(10 psi)
14 kPa
(2 psi)
Go to Step 24
Go to Step 6
6
Start the engine.
21-69 kPa
(3-10 psi)
Go to Step 7
Go to Step 8
7
Go to Step 17
8
Idle the engine.
Go to Step 21
Go to Step 23
9
Go to Step 23
Go to Step 10
10
Go to Step 19
Go to Step 11
11
Go to Step 23
Go to Step 20
12
Go to Step 14
Go to Step 13
13
0 kPa (0 psi)
Go to Step 16
Go to Step 17
14
Go to Step 22
Go to Step 15
15
Go to Step 25
Go to Step 23
16
Go to Step 23
Go to Step 17
17
• The fuel filter
Go to Step 25
Go to Step 18
18
Go to Step 25
Go to Step 19
19
Go to Step 25
Go to Step 24
20
Go to Step 25
21
Go to Step 25
22
Go to Step 25
23
Go to Step 25
24
Go to Step 25
25
System OK
Go to Step 3
i did the fuel pressure test today.
When cycling the key the fuel pump runs pressure at 50 psi
as soon as the fuel pump stops it drops to zero
When cranking I get close to 50
When running it is 50
As soon as i turn the car off my pressure drops to zero
If I open the valve the release fuel on my pressure tester the engine dies pressure drops
Either the fuel pressure regulator is bad or the fuel pressure relief valave on the fuel pump is bad.
I would bet it is the fuel pressure relief valve on the pump.
I got a pump from napa
removed the pump
cut and spliced the wires
because the connector is different
Went to install the pump and the top of the pump is different
the position of the tap and where the lines go are in a different place
along with the type of gasket being used
but the pump is the same just the top is different
the proplem was a crack in the clear line that runs from the pump to the top
I replaced it with a rubber fuel hose it runs fine now.
Since it's my only vehicle I had to do somthing to get it running
But know I have a evap leak
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
