Electric Fans - Strictly An Economy Question
Ok, I've searched the archives on this site as well as a few others in regards to upgrading to electric fans. The lack of information directly pertaining to increases in MPG's is quite surprising (based on my limited searches). I've read the how to's, which radiator, alternator upgrades, stock vs aftermarket, stand alone controls, wiring harnass for pcm controlled with tune, etc....
So this post I would like to be answered only regarding increases (degreases or no change) in MPG's after the fans are installed. I'd like to hear it from people that have personal experience with it and have real numbers to report. Please also include your fan setup (Stock or Aftermarket). I just don't want to have to shell out the 400 bucks (give or take) to find out it's not really going to give me what I'm looking for. I have a 2003 GMC Sierra 1500HD 6.0L 4WD w/Quadra Steer.
I will be able to tell you soon, as I'm about to put some ls1 fans on my 2004 w/4.8 in the next 2 or 3 weeks. The potential for better mileage definately exists though. You will hear lots of talk about the extra alternator draw equaling out the fan clutch draw. At full amperage maybe that would be true, but seldom will your fans ever need to run full blast, especially if you use the Delta Current fan control.
Welcome to the site Matt.
I don't know the exact answer to your question but here is a free bump. :D
Yes Sir ! Would like you fries with that order?
I am just trying to focus the post on a specific response as many of the posts I've read never seem to get answered in regards to mpg's specifically. I think there are probably a few people out there that would like to see some answers to this question. I did not mean to come across in a negative manner, just trying to learn.
Looks like you are going about it the right way to me. Hopefully the right person will see this and chime in. Simply by searching before asking your original question you are ahead of about 75% of us.
Free bump for you as I am interested in some tangible numbers as well.
I bought my 6.0L Yukon XL primarily as the family hauler but it also has the secondary function as a tow vehicle as well. Either function could benefit from better MPG. A 1 MPG increase could be worth the cost of the initial upgrade.
Here are some reviews from users that bought Flex-a-Lite fans. I saw others that claimed 0-2 mpg. You seem to be a bright person so you know the pitfalls of people making big claims on either side of the coin on the net.Tym Byrne on this site, who is a vendor, claimed 2mpg but says he made two other mods at the same time. Not knowing what those other two mods are detracts from the claim. He also sells them so you might want to factor that in.
Boomer
Very Good Buy - 07/18/2007
Reviewer: From A Customer Own this product - Yes
From brownsville, tx
Temperature does not rise above the O in normal. When i use the A/C temperature rises fans kick in a coulpe of minutes temp. goes back down to normal.
5 out of 5 stars 2000-2004 nissan xterra 3.3 - 08/02/2006
From Hot as heck California
Fits like a glove, requires aftermarket rad to use these directions. clip the 2 "L" shaped brackets with bolt cutters, drill a small hole in the small end of the bracket & edge of rad, mount bracket. cut a 2"x2" off the lower drivers corner, (to clear steering box) mount on long part of "L" bracket, and mark for size. remove fan, Clip "L" bracket shorter, and reinstall fan. Reinstall rad, and wire. Directions are great, will need a good crimper tho, I soddered mine. If anything it is almost overkill, 115 here and the AC blew cold.. almost too cold at idle. only downside is the fan runs as long as the ac is on (if wired for that) and this includes 70mph on the freeway, where it is not needed.. a second thermostat on the condensor would be sweet..
4 out of 5 stars Cool deal - 07/11/2006
From Houston - Vehicle: 1987 CHEVY/GMC TRUCK Suburban
Big performance gain. I was really surprised. Excellent fan, all ajustments are right on. Wish I would have done this sooner. This is on my 88' Sub. with a H.O. 5.7, and I tow qiute a bit.
1 out of 5 stars Things to know about this fan - 07/10/2006
Reviewer: Mark Carter Own this product - Yes
From O'Fallon, Mo. - Vehicle: 1999 DODGE Ram
I bought this electric fan and made sure to order a vehicle specific fan so as not to have as many issues with the installation. Problem was when I received it the mounting brackets that came with it where no where near what I needed or could use, so I had to make my own. The instructions for all the wiring where extremely vague. My roommate is an electrician and he had trouble figuring out what some of it meant. I have noticed very little change in over all performance or gas milage if any. I am very unhappy with this order and would not recommend it to anyone else.
Thanks Boomer, I am really more interested in data relating to LSx powered trucks. I've seen it for other vehicles, I read an article about a diesel Ford that picked up 3 MPG with this upgrade, but it's not really comparing apples to apples.
Tage, I tow a 6500 lb camper with my Yuk XL and researched the e fan subject a great deal before deciding not to do it. I am sure there are gains and they certainly clean things up under the hood but I researched this on s RV forum and finally a comment hit home with me. The comment was: "Have you ever seen a 3/4 or 1 ton truck with e fans?"
I finally came to the conclusion that my fan clutch was working well and I kind of like the fact that I have to put an orange cone out in front of my grille when I am at idle in a campground. I do this to keep small children from being pulled into my grille. :sigh:
I finally came to the conclusion that my fan clutch was working well and I kind of like the fact that I have to put an orange cone out in front of my grille when I am at idle in a campground. I do this to keep small children from being pulled into my grille. :D
Now how many kids did it take before you started using the cone? :sigh:
Good stuff man! Thx for the input. I suppose the bigger the motor the less of a difference a clutch driven fan is going to make. On 3 cylinder engine Geo Metro it's going to make a lot bigger difference than on an aircraft carrier engine. I'm still curious if there's anyone out there that has any actual numbers (specifically with a 6.0L engine) but at this point I'm interested in any engine MPG numbers.
Probably the biggest reason to not do it is my wife will be pissed if the electric fan burns up or the truck simply overheats on a 115 degree Phoenix, AZ summer day. I'll never hear the end of her bitching saying, "why can't you just leave well enough alone?". :sigh:
I finally came to the conclusion that my fan clutch was working well and I kind of like the fact that I have to put an orange cone out in front of my grille when I am at idle in a campground. I do this to keep small children from being pulled into my grille. :P
Not but 3 but fortunately I was able to peel them off once the engine was turned off. I did not mention the little poodle dog because the outcome was not so good. :D
That's the thing about kids... they get into everything.
    DM22
    DM22
  • Who's Online   4 Members, 0 Anonymous, 1,691 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • As a matter of amusement I’ll leave this conversation with this. Do you beat the government average fuel estimate? Statistics are a guide to me. Not a rule. Someone once said I have to have the last word. If true and possible may be. I’ll blame that on working in a family business.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
