Has anyone had a problem programming the garage door opener to there truck? I am unable to get mint to work and when I called GM they gave me an 800 # to call the people that make the unit in the truck and they were unable to get it to work, but for $10 I could order some thing that would make it work. That sucks when you pay $27k for your truck you should be able to open a freaking garage door. :)
PS TGIF ; )
I found that it was very easy to program a rolling code opener to the truck but very difficult to program a non-rolling code opener (I have one rolling and 2 non at my place).
So which are you having a problem with (rolling or non-rolling code)???
A rolling one..
I didn't have any problem with mine, I didn't even have to program it, it just knew. :) Kiddin'. What kind of garage door have you got? I thought it was fairly straight forward, but the procedure varies by door.
It’s a Genie and is pretty new..
I'm a garage door mechanic and the rolling codes gave me some problems as well. Its not very clear in the instructions, but you have to follow BOTH sets of instructions (for non-rolling AND rolling codes).
I'll give you a step by step just to give you an idea, you can fill in the rest from the instructions.
1) Clear the codes in the truck
2) Program the truck using the non-rolling instructions (Holding the remotes very close to the buttons in the truck)
3) After you get the truck programmed for the non-rolling, go ahead and program it for the rolling code now (Using the smart button on the operator and holding the button in the truck)
That should do it, but like I said just take the steps I gave you and compare them with your truck manual and it should be fairly easy to figure out. If you still have problems let me know.
Edited by bobf1234
I did my Geine last week. (That sounds porno...LOL :) ) It worked fine. Start with the garage door open. Push and hold the 3 buttons in the truck I think until they flash, you might check the owners manual on that.
Then go push the button on the opener motor and run back to the truck and push and hold the button in the truck that you wnat it to be. Hold the truck button until the door closes then let go. You're done! It took about 7 to 10 seconds for mine to find my code.
Just don't let go of the button in the truck until the door moves.
Edited by Heysdad
I'll add:
1. This could take as long as 30 seconds before the door moves when programming.
2. DO NOT repeatedly press the "learn" button on the genie motor without attempting to program a remote or letting enough time pass for the LED to stop flashing before pressing it again. Pressing it too many times in short period will erase ALL remotes from the motor (I did this at my dad's house by accident, so I got his car programmed but all other remotes tied to this opener were deleted and had to be re-programmed.
3. This one should be obvious: DO NOT park the vehicle under the door while programming (be completely in or out of the garage when programming).
Well I have done all that an still no luck :)
...Dang I just did mine and opened my neighbors door across the street. Just kidding. What did GM tell you to buy for $10? That would probably be cheaper for me then spending an hour trying to program the two systems.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
