Bpmv Porting - Brake Line Routing
drcmm
Just replaced totally corroded brake lines. Need to know the porting on BPMV for 1999 Silverado 1500 4x4 with ABS. Any assistance would be appreciated. Thank You
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 968 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
