Will These Wheels Fit My Truck?
Welcome to the group, by the way.
You need at least 17" wheels, which you have got. But the bolt pattern should be 6x5.5" (or 6x5-1/2") to fit your truck. That's the GM six-bolt pattern.
Also, you should look for 4-1/2" backspacing and zero offset.
That's the standard gm truck wheel. If you go to www.americanracing.com, for example, you'll see that this combination (6x5.5", 4.5" backspace, zero offset) is a "stock" combination for gm products.
Good luck!
P.S. Don't mind Hubbycap, he's just grumpy. He'll loosen up a bit once he gets to know you. :banghead:
