Brake Pedal Goes To The Floor?
xtrempickup
I have a 95 K1500 Chevy Stepside 350 truck with automatic trans. Up until today, the brake pedal was firm when pressed to stop. Well today is the first snow we've had, first ive driven it in the snow. ABS works, thats for sure. But I'm getting a pedal that when pumped will stop, but otherwise is dropping to the floor board. The fluid is an an acceptible level, it hasnt fallen. The master does show any external leaks, and the truck is a low mile truck, its a very clean body and underside 70K miles and i dont see any external leaks from lines or anything on the ground. it just totally lost pedal and only seems to make pressure or have resistance when being pumped. it has a brake booster, its not like the diesels with a hydraulic booster than runs off the PS. my question is, what should i be looking at? is the master bleeding off internally? is the booster itself possibly leaking? what is the major culprit with this type of problem other than obvious breaks in the system that sort give it away? should a master thats 13yrs old and 70K miles possibly have gone bad?
does it do it sitting still or only when in an ABS event.?
does it sitting still and while moving, when abs engages it has a very hard pedal and that standard abs pulse to it
check for air in the lines, maybe bleed the brakes.
dont know why air would be in them, but then again, it wasnt this was earlier til the ABS first engaged at a stop. after that it was sinking away on me. i havent touched the brakes, they have not been done recently, they are good, but they have use on them
well ,if you have no leaks at all,then the m/cyl may have failed
thats what im thinking, but wanted to cover my bases before i purchased one and started taking the old one off the truck
what about the possibility of the ABS pump bleeding off pressure? i know its sort of a decoration unless its engaging. leaning toward master considering the fluid looks like mud and it still makes some pressure and the abs when it kicks in the pedal does get rock hard and it pulses like its working. level isnt falling in the reservoir.
hard pedal is the result of an event,if there was a an ABS problem,there would be a code and when that happens ,there is no more ABS,just base brakes.
so if its a ABS related problem it should throw a code and store it. funny part is that the brake light has not come on at all even tho it acts like it has no brake pedal and the ABS hasnt, usually only get an abs light when there actually is a ABS related problem
just logged on and saw your post. i had to replace the brake booster in my 98. i was kinda having the same issues but one thing different was that i was getting a hissing noise from it.
same symptoms except for that.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
