Front Turn Signal Problem
I go outside this morning and my front right signal is not working neither bulb. So I check the bulbs and they are good, so then I check the fuses and didnt find any that were bad. Is there something else to look at or should I take it to the dealer. :jester:
Good news, I was at work tonight, mechanic at a bowling alley so I could go out back where I park my truck and decided to check one more time. I found a blown fuse in the dash. I had also noticed that my interior dome lights were not working when I unlocked or took the key out of the ignition. Anyways I found a fuse marked ctsy and figured it was for the interior and it was. So I replaced that fuse and the interior lights worked. Then I tried my front right turn signal and it worked. Odd that they were on the same circut. :)
