Question About Alt/regulator/volts
Rosedog
I realize I should have posted my original question here now.
The other night I noticed, on the freeway, when my engine had a load (3rd) on it my volt gauge dropped below 14volts but when it went back into drive the volts went back to normal.
Then yesterday I put into 3rd when accelerating on the freeway and I watched my volts drop down to 12 but once again when it went back into drive the volts went back to normal.
I stopped by Schucks and had my Alt tested. With the truck idling I was told everything was normal but then when I was told to put a load on it (lights, heater, stereo and to put the tach at 2 rpm) it then gave an error saying there was a "ripple" in the charging system. It was explained to me that the Alt was pulsing and that my regulator was most likely bad.
On my way home from Schucks when I was at a red light I was watching my volt gauge again and I noticed it would drop a tick and then come back and then do it over again.
I have already had my Alt replaced by the dealer a few months ago so I called and will be bringing it in on Monday.
I've never heard of that term before (ripple), is that an actual term? It did kinda start to make sense though, I had noticed would get in my truck at night my dome light would pulse almost really fast (not on/off but more like bright/dim/bright/dim/bright).
Could this be something else like the battery?
Well I got my truck back from the dealer. I was told that they couldn't find the problem, which makes me think that they didn't attempt to (I told them how to find the problem and I know that works because it did everyday till I brought it there).
With all that said and done they did swap the Alt. out anyways since it under its parts warranty. I took it out ran it through the lower gears with higher than normal RPM's and the volts stayed the same not coming down.
Still got no answer on the term "ripple" though.
I thought Ripple was a type of alochol, cause i always read that term in midwestern type of movies and it related to something they were drinking
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
