4l80e Strange Behavior..
caddy
I´ve got 1995 6.5 turbo diesel GMC Suburban. 230000 driven. I´ve owned this wehicle for two months soon.
Stange troubles appeared after driving few hundred miles. (Means I´ve driven few hundred miles with that now) Tranny does not work as it should. mad.gif When driving ~50mph the tranny can´t decide which gear to use.. lock on and off.. And wehicle moves then really sticky, does not matter if it´s cold or warm. Revese sometimes does not react to accelerator pedal and sometimes it works fine. Is this kinda solenoid or sensor problem or what? There is only one trouble code, 36 (injection pulse width error(time long)). Does it relate to this problem? PMD/FSD is new and remote mounted. Fuel, oil and air filters are new and motor oil of course. Tranny oil is still the same, what there was, when I bought this Suburban. Oil level is allright.
I had 1994 6.5 ext.cab before and it moved much slicky with no this kinda problems ever.
Any ideas??
I thank You beforehand!
Juho From Finland
:jester:
that trans is a fully electronicly controlled trans. i should know, I just sold my 95 6.5L automatic ext diesel. they act dependent on the motor. if the motor is functioning properly, as in everything, the trans will act accordingly. i had one that was sketchy and after i got the motor functioning correctly, the trans worked perfectly. hard to diagnose them, but could be solenoid related or could be torque converter related, those go bad in them and cause problems. mine would not lock up sometimes, shudder other times, get stuck in 2nd and other times run fine for weeks. if its been serviced a reputable trans shop should be able to drive it and diagnose what your problem most likely is. thats how i found out the motor function has a lot to do with the trans function on these trucks. That trans is a strong trans, but likes when things are correctly functioning with it
HI!
Thanks for Your ansver!
I`ve thought something like that. It is not necessarily trans` problem.
Where is TP sensor located? May it be the reason? :jester:
HI!
honestly a factory shop manual would be your best best to locate stuff on that truck. i sold mine, actually happy its gone. if you dont have a manual yet, get one. are you a member on the diesel forums? good place for a lot of help, it was for me.
http://www.thedieselpageforums.com/tdpforum/
Now I´ve changed trans oil and filter. Oil was really dark, but there wasn´t any metal or other material in oil pan.
I noticed that accelerator pedal have sometimes problems with front gear too.. Engine ran only idle and does not react to acc.pedal. There was a little uphill and that is why truck does not moved forvard even with idle.
This is not trans problem anymore.. There is still no other trouble codes with 36. :)
36 has to do with the PUMP driver which you said you replaced and relocated. have you reset the codes and see if it codes back?
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
