08 Tahoe Replacement Tire Question
Snapster
Looking to replace Bridgestone Dueler AT 18" tires on our '08 Tahoe with a summer tread, but there are very few avaiable in the stock size.
Will tires with a different outside diameter mess up the monitoring systems for the abs, stabiltrak, and tire pressure monitoring?
I know that the optional oem 20" tires seem to have an OD that is 1/2" taller.
Does the vehicle make any necessary adjustments (if any are needed), or does the dealer have to tinker with it?
If they have to make changes, can it accomodate any size, or just the oem standard and optional sizes?
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 1 Anonymous, 746 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
