K3500 Rough Running
hi
I have a 96 k3500 7.4l that is running rough at idle and useing a lot of fuel.just changed plugs cap rotor wires (checked for right order multiple times)when I pulled the new plugs # 2 6 8 were black and # 4 was clean.no codes. 55 lbs of fuel pressure running after I shut eng off pressure stays the same
Oily black or sooty/ash black.How many miles on it what did plugs look like that came out.Maybe vac leak ecm is enriching to correct.check simple stuff like stuck open pcv valve.Seen many a tbi base gasket do this.Good luck.
  • 4 weeks later...
Wouldn't happen to be running an oiled foam or guaze air filter are you? To much oil will coke up your MAF sensor and get you some unexpected problems.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
