Transmission
hi to all i am new to this site and i had a couple of questions first off the vehicle in question is a 98 chevy C-1500 Silverado with a 5.7 and a 4L60-E the questions i had were these i have heard rumors about the valve bodies in the transmissions going bad also the sun gears going bad and my second question is my truck has this problem of shifting hard into second gear when the truck is cold it does it also when its warm but not to the extent that it does cold and i was wondering if i could get some advice on this one thanks
ryan
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
