Tailgate Latch Broke
Well my latch rod on the right side of the handle has the little plastic piece broken off of it. Can I get this little piece from the local auto store or is it a dealer thing. It is the piece that holds the rod to the handle...and of course I broke the handle bezel prying it off.
Is this the nylon clamp that clips back onto the rod? Your parts store should have it; usually a couple in a pack. They might even have the bezel, but that's probably a dealer thing.
Good luck.
You can get both from the dealer. Mine did the same thing. They are only a few bucks for the plastic piece.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
