Leveling Kit In Front And 2" Blocks In Rear? Nbs
Anyone tried this? I know it kinda defeats the purpose of the front leveling kit, but I like the back a little higher than the front. So I was thinking for getting the front 2" leveling kit and finding a 1" or 2" block for the rear.
Anyone else thought of this or done this?
Sounds like you should check out truxxx.com
Thats what I plan on getting in a few days check it out
I just raised the front 2" with new keys (Truxxx) and put a set of 1.5" add-a-leafs in the rear. The truck rides great and looks good. With what I did, the back is still about 1.5" higher than the front.
truxxx.com
Sweet, looks good. Probably do this when the time comes. Only thing is.. Its $350+, you can buy a 2" front leveling for $120, and I'm sure you can find cheaper blocks for the rear.
  • 4 weeks later...
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
