Quick Question
Guest Riggs
Guest Riggs
Alright i dont have a intake on my truck just the K&N OEM Airfilter. soooo I bought a 14 inch Edelbrock pro flow air cleaner, and got rid of the tubes going to the side of the fender, i swear to god i can atually tell a little bit of a difference. i was a little suprised, but i was then thinking, the air filter is only 2inch tall so i could get a 3inch tall 14" round air filter from k&N and boost my hp up even more. the threaded stub on top of air cleaner is long enough.
not only that but now i have room for a 2nd battery :chevy:
Do you think it will be worth the $40-50 bucks for the air filter?
P.S - i read on the website it will gain 6.XXXX HP with the air cleaner so if i get the air filter it will gain that much!
P.S.S My Truck has MANY MANY Upgrades/ New Parts pics will be coming soon i just need to get a few more things that are ordered!
Guest Riggs
Ahh, never mind i found that the k&N is less than $30 bucks for a 14"x3" air filter so i will defintly be getting it.
theres just something about k&N that i think is so much better especially since you can clean them unlike regular air filters, then i was thinking a outerware to go over top of it :chevy:
the bigger air filter you get will not always give you more hp. Your engine will only suck in so much air that it needs and you could have a filter on as big as your hood and it won't add more power. Only if the filter is clogged or very undersized in the first place will getting a bigger one make a difference.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
