Clearance Question
Maybe this post will do better here. 1st, how do I check if I have auto trac?
2nd: I have 2002 Yukon, and I was thinking of installing this lift kit for a little more clearance from Pro Comp. http://www.4wheelparts.com/PDT1637.aspx I chose this one because it doesn't replace the knuckles, keeping the rack width the same so there's no 3" front tire kick out. I was thinking of going with a 305/70/17 tire.
The question is what is the max width (in everyone's experience) I can go on a 17" rim with ^ that tire size without have the tread sticking out of the vehicle body. I can't have any tread sticking out for legal purposes.
Anybody have an existing size, or know of the configuration which would accomplish this?
Aloha!
That's pretty much the kit I have. 8" wheels will keep it just at the fender. As long as you use pro Comps recomended backspace. 10's if you have the fender flares.
You have Auto trac if you have a push button 4wd and it has AUTO as an option.
Thanks for the reply, James. Looks good, and I NEEEED to keep the edge of the outer tread in line with the lip of my fenders. Thanks again, Bro! :shakehead:
backspacing on the wheels makes a difference in the overall width, plus you usually want a slightly wider stance to compensate for the vehicle's center of gravity being raised (more chance of roll-over). im not one for those W-I-D-E track vehicles, but some is necessary.
Everything depends on everything else.
the width of the tires, the width of the rims, the backspacing on the rims, and of course the lift itself.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
