Vehicle Options
Hey Guys! I have 2002 Yukon and shopping for a lift. I was wondering if "auto trac" is that Auto 4WD button and the top of the drive select panel.
Also, how can I tell if I have autoride suspension? For the life of me I can't find my window sticker.
Thanks for any input or points in the right direction. :D
Yes Autotrac is the auto t-case, the auto 4wd button.
My 01 tahoe has "autoride" written in the LT badge by the door pillar, or check your shocks for airlines, you also hear the compressor level out the suspension when you start the rig. I BELIEVE only LTs/SLTs have this option, is yours an SLT?
Thanks Alaska! No mine is an SLE, and I checked per your advice and no air lines, so no Auto Ride. I always buy my trucks with as little options as possible as I normally rip everything out anyway. Thanks so much for confirming this.
Aloha!
