chevy truck like a knock not a tick :lol::lol::lol::D:lol:
Yeah, they knock toyoduhs out of the way :lol::thumbs::thumbs:
that would never happen because a gm could never catch a tundra :lol::lol::lol::lol::lol:
Wow, you must have the Super-duper fast one with 6 D-cell batteries huh? :D
  • Replies 391
Top Posters In This Topic
speaking of knees ask the mrs how much i owe her :lol::thumbs::thumbs::lol::lol:
Why, did you scrub the floor for her?
Edited by VMax2007
Boy, times must have changed. When I was in highschool I was out trying to get laid on a Saturday night.
and what was his name :lol::thumbs:
Even though you are not used to dating girls, most of us are normal and do like the oposite sex. But I see your point, you do up your chances of getting a date if you swing both ways.
If your so proud of your douche mobile why dont you stay on their forum
Guest Riggs
Why, did you scrub her floor for her?
needed money for a new tailgate
Oh, now that's a real "kneeslapper". You come up with that all by your wittle ol self?
why, my wife is not a lesbian
Edited by dlstewart01
I can only accept this from someone who actually owns a vehicle...what a loser
He was banned there too
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 0 Anonymous, 693 Guests (See full list)
    • They’re not the same wiz as 10-15 years ago.  QC has fallen pretty hard.  The XP line was never good though in the first place.    https://bobistheoilguy.com/forums/threads/wix-filter-rusted-through.386492/post-6991372   https://bobistheoilguy.com/forums/threads/i-ve-used-my-last-wix-filter.27299/   https://bobistheoilguy.com/forums/threads/looking-for-a-better-replacement-for-wix-51258.403977/   https://bobistheoilguy.com/forums/threads/convince-me-in-using-the-purolator-boss.401537/post-7420147   the forums are littered with posts and examples of not great wix filters the last couple years
