Squeaking Window
I've got a really squeaky window in my new Denali. Goes about half-way up and squeals the rest of the way like nails on a chalkboard. I am assuming there is something in the seal.
Any suggestions on what to clean the window channel with? I think it is the gasket that wipes the window at the bottom of the window opening.
Bish, I have the same problem. Both of my front windows do it, going up and down. It sounds terrible. I had it in to the dealership for this problem once and they pretty much told me that there was nothing they could do about it except lubricate something a little bit (I forget what, but I don't think it was the channels). It's gotten worse since then and I'm making another appointment for it next week. There may be a TSB out for this problem, if I remember correctly.
There is a TSB. It says to lubricate the regulator. My passenger window does this, but I haven't taken it in or done anything yet.
#07-08-64-019: Front Door Window Regulator Squeak Noise When Operated (Apply Lubricant) - (Nov 13, 2007)
Lube the regulator as in the slides and cable? I'm pretty sure in my case the squeal is coming from the center of the window where the inside or outside weatherstripping contacts the window face as it slides down. I'm afraid of lubing it as I don't want to get the window all greasy every time it goes up or down. Maybe I'll try a little silicone spray and let it dry before operating the window.
Drives me INSANE though and we are just now hopefully getting to open window season up here!!!!!!
Don't worry...my 2008 Silverado does it too on passenger side. Kind of crazy this would slip thru on a $44,000 vehicle. I'll take it to the dealer if something else comes up. At least I'm not the only one!
Both of my fronts did it too, but after a month or so, it went away. IT DROVE ME NUTS!!! I'm certain that there is a TSB on it because I printed it and have it in my center console. I was going to show it to the dealer when I take her in for her first oil change, but now it's a moot point. I still have the dreaded oil leak, though... :crackup:
The TSB states to lube the regulator rails. Mine has gotten better on it's own over the last couple of months and I haven't used the window much. When the truck was new it did screech pretty good and I thought it was the weatherstrip on the glass. If we ever get to window open season I'll worry about it more.
I can now state that silicone spray does not improve anything. I tried it last night.
I'm still convinced it is coming from the weatherstripping as I can see something on the glass in the area it starts to squeal when raising.
Guess I'll try and raise/lower the windows a few dozen times to see if it gets better.
I don't want to hijack your thread Bish, but have you (or Victor, or anyone else) noticed that the sunroof is a bit noisy as well? It seems as though mine makes some noise when going over bumps, and also when cruising along over ~40 MPH. It seems to not be sealing correctly, and I was just wondering if I'm the only one experiencing this.
I've hijacked my share so no worry.
Mine actually squeaked a little when going over bumps when I first took delivery. I took a rag and some dielectric grease on the gasket around the roof and that seems to have stopped the squeak. Truth be told, I haven't noticed any noise with it closed. The few times I have had it open, it seems quiet driving. I think the plastic skirt on the sides helps with noise. However, I tend to keep the radio up to compensate for my tired abused ears so I may just not be hearing it. I guess my parents were right when they said I would go deaf if I kept listening to music that loud :crackup: I don't know if the cab on the Sierra is less rigid than the bigger box of the Yukon but I wouldn't think there would be any difference.
Also, just so you know, I crack up every time I read your username and look at your avatar as I'm a Red Sox fan having grown up outside of Boston. I have a good friend/neighbor from NY and he is a huge Yankees fan and we have lots of fun with it. I give his kids Red Sox stuff for xmas so they can burn it in a ceremony :crackup:
Haha that's great Bish. I'm so glad that spring training has started; should be a great season!
Sounds like the Yanks are a little feisty this year. Mixing it up with the D-Rays today after the "catcher" incident yesterday. Baseball season may be too long but I LOVE spring training. Especially after such a disappointing end to the football season....for a New Englander that is. I'm sure you have a little different perspective...then again you should be a Bills fan.
Where is your oil leaking Victor?
Will, to answer your other question first, I don't have noise coming from the sunroof (thankfully) and the squeaking from the two front windows is all gone. All seems normal, so far, except for the oil drip.
Apparently, there are a couple of TSB's out on the oil leak thing. I don't know EXACTLY where it's coming from, but it's there. My first oil change is almost here, so I'll have the dealer look over the truck and pinpoint where the problem actually is. Here are three pics of what it looks like under the truck:
Yes, I am a Bills fan :crackup:
Anyways, I've yet to notice a leak on my truck but I do smell burnt oil every now and then. I'll have to have the dealer check it out next time I'm in there.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,079 Guests (See full list)
