Rough Country Install
I'm gonna install my leveling kit this weekend and I need some advice.
My question is do I need both front wheels off the ground during the install or can I just jack up one side at a time?Reason I am asking is because it's a tight fit in my garage and I don't have enough room on both sides to do both at once.Plus my driveway isn't level.
My be a dumb question but oh well.
Yes you can do one wheel at a time, make sure you run the bolt all the way up on the front sway bar attached to the lower "A" arm as this will allow the bottom "A" arm to drop more so you can slide the spacer in on the bottom, that way you dont have to break the ball joints loose.
What kit are you installing? I am trying to decide the easiest way to raise the front on my new 2008 Chevy.
    Brendan C
    Brendan C
  • Who's Online   0 Members, 0 Anonymous, 972 Guests (See full list)
