5.3 Or 6.0?
Well,
I am hoping to be buying a new Sierra or Silverado soon, 03-04 some where in there depending on the price.
I was wondering what I should get, a 5.3 or the 6.0L Is there that much difference in the HP ratings? I think it's something like 30 hp? Not sure though on this one.
But most of the trucks which have the 6L are 3/4 versus a 1/2 ton. There are a few 6L half tons, but they are the HD versions and seem to be quite a bit more expensive. Will I see a difference in driving a 3/4 ton versus a 1/2? Should I get the 6L or 5.3, also is any of these more fuel efficient, I am guessing 5.3, but how much worse is the 6. if that is the case.
3/4 ton will i notice the weight difference? Im not sure if I need 3/4 I just need 1/2 I think. Some basic lifts, 6-8 and some bigger tires. I would like the HD version though because of heavy duty parts.
Also how long do these trucks last I found a few with a bit more millage but more options that I want like the interior and crew cab.
Inaways sorry for the ramble. I searched for something like this but didn't find anything, maybe I needed to search something else. But my options are:
Probably 1/2 HD. or 3/4 or 3/4HD.
Crew hopefully.
Will I like the 5.3 or 6L better I do enjoy power and am leaning towards the 6, but if it affects gas millage harshly also due to the size I don't think it's worth the extra $$$
The motor choice depends entirely on your application. It appears that money is a concern, both for buying and then feeding the beast on a daily basis.
For a normal use application with limited/light towing, the 5.3L w/ 3.73 diff moves my truck down the road just fine. The 4.3 V-6 in my old truck performed fine too for my needs. Throw in a lift, larger tires, added weight of an HD or 3/4 ton, etc... you can then forget about fuel economy with either motor. This eventually becomes a question of priorities. Believe you need to ask yourself if the truck toy is worth the financial sacrifice. I enjoy my '07 Silverado but at $3+/gal for gas, it spends most of it's time locked in the garage.
Well, I think I will got with the 6L if it isn't that bad. My current truck is already horrible. Heh so no changes there. But how much extra weight does the HD package add on? Or should I just Upgrade to the 3/4 ton. The 1/2 hd's seem to be a bit more expensive too.
If money is a concern and you don't need the capabilities of the HD then I would just get a 1500 with the 5.3. It is a fine motor and it get's pretty good FE.
But if you want the bigger truck get it. It's all about what you want and need.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,233 Guests (See full list)
