2001 2500 Hd Compatible Take-offs
Wondering if anyone knows of any more modern rim/tire combos on GM vehicles that would work on an older 2001 Silverado 2500 HD.
I'm looking for new tires and figured I'd try to see what else is compatible. I did see a 2005 Hummer H2 rim/tire is supposedly compatible but they don't look that great. Any input would be great, thanks
