05 Speedometer Not Covered
So i went to the chevy place today to see about getting my speedometer warrantied in my 05, and turns out GM is not warranting the 05 models. Good thing i got a family member working in parts thats got some pull, its getting replaced tomorrow on "good will". He called delco and they said that pretty soon they would start warranting the 05 models also.
It was my understanding the speedos were covered to 70000 miles.
I've had my 05 in for a few items, all either warranteed or Goodwilled. My truck is creeping up on 70k. I am waiting for the cluster to start acting up.
Yeaht they're covered up to 70,000 miles on the 03 and 04 models only. 05 is not covered at all. But the people at delco said that they probably warranting the 05s soon. How about they are replacing the steering shafts instead of just greasing them to get rid of the clunk. That seems like a waste of money.
