Fuel Issues
slyrfn1986
I have an 88 Gmc 1500 4x4 305 engine carburated 4 barrel and im not getting any fuel we believe it might be the fuel pump as there isnt anymore sound when you turn it on...when you prime the carb it starts then quickly dies as there is no fuel going in...now before we go and change out the pump we tested the electronics with a meter and got no signal from the harness from the pump. the harness to the dash fuse box had a reading and oddly the fuse box had nothing as well.. i cant seem to figure anything out what are some options? I get spark from the plugs and also the fuse that goes to the pump blew and we changed that Im lost Please Help
I am going to buy the whole pump kit with the sending unit and harness all attached and plug it in tomorrow as well as a new relay just to see if it was either of the two basic things..if not i have a feeling it maybe in the electronics in the whole truck are screwed up. Which i hope isnt the problem...and the engine isnt fuel injected anymore it was converted to carburated older engine from an older gmc but the idiot left all the remaining pieces there wires etc so its a bit harder to figure out but im praying its the basic one thing that we havent done the fuel pump itself im trying tomorrow..
Any other questions just ask
Please reply to [email protected] as i check my main emails everyday
Thanks for any help!
    Matt Parker
    Matt Parker
  • Who's Online   2 Members, 0 Anonymous, 781 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
