Tourqe Converter
Guest Riggs
Guest Riggs
Well i just put in a new Throttly body, turns out mine was from a s10 pickup..... (not good) so i got the right one for my truck and now it has like 2x more power and the cruise even works now :lol:. well i used to have the TQ wired up to this switch, but now that it is right i dont need to switch anymore, i went to put it back to stock and i have no power coming to the TQ converter any more... it works when i have it hooked up to a switch but not automaticly
Could this be caused from a TPS? i really have no idea what could cause this since before the switch it worked like a champ.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
