I have found several links for pulleys and will probably be getting them from either March Performance or Jet . . as these are the only two companies I know that carry them for my 'lil 4.3 and I can get both at cost (or near cost). Does anyone have any experiance and/or preference on either of these brands? . . . also the March one depends on whether I have an external alt fan or not. . . how do I tell? . . I have a reg. clutch fan but will be upgrading to e-fans shortly. Thanks for the input.
Jet Pulleys:
March Pulleys:
Jet Pulleys:
March Pulleys:
I think, but may be wrong, they are referring to the design on the pulley itself. If you look at the March pictures, I believe the bottom pulley represents an external fan-type altenator pulley. If your stock pulley looks like that, then that is the one you need. If you don't get any other reponses from some mechanics or people who know, I would maybe ask your friendly neighborhood parts guy or just give the company a call who you will be buying from.
Jet Pulleys:
March Pulleys:
Awesome, never thought of that . . Ill be sure to look into it
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
