1994 Suburban Intermittent Ignition & Electrical Failure
FALCON2
1994 C1500 5.7 Suburban automatic. Problem is intermittent and occurs occasionally while driving under normal conditions. What happens is that the ignition system will completely cut out. When this occurs the instrument panel gauges (Oil & Temp) freeze at whatever condition the engine was operating at, and the Volt meter drops to zero. I may even recall the speedometer freezing in place. When attempting to restart, the engine will turn over. but the first attempts to restart usually fail due to no spark. One thing to note is that the gauges will not reset (oil press to 0 and temp to current engine temp) and the voltmeter still registers 0 volts when the ignition key is turned to on. The first indication I get that the the engine will restart is that the gauges all reset when I turn the key on. When this problem first started, the engine would usually restart after several attempts, now the time between the failure and a successful restart could take more then a day. The other thing to note is that, in most cases when I finally get the engine to start, as soon as the transmission is taken out of PARK and placed into gear the fault immediately occurs along with the gauges freezing again, and then I have to sit and wait from anywhere from a couple of minutes up to hours before it may start again.
The truck has a new ignition system including distributor and new coil, and a new ignition switch, all of which had no effect on the problem. I swapped the ECM from the Suburban into my my 94 Silvarado PU, and the ECM tested good, so the ECM itself appears not to be the problem.
They are. I don't loose any of the other electrical systems when this occurs and the starter turns the engine over without any problems.
Because of the way it instantly fails when the transmission is taken out of PARK I'm thinking that this might be caused by something inputting to the ECM from the transmission. The only problem is that this doesn't occur all the time. sometimes I do get into gear and the engine will run fine. The last time this happened I ran the truck for a day with no problem until the very end of the day when I had to stop, put the trans in PARK, and then when I put it back in gear it stopped. I ended up having to get it towed home after trying for several hours to get it started. The next day it started without any problem, although as soon as I took it out PARK it stalled again. It also doesn't matter whether the engine & trans is hot or cold.
Your problem has the characteristic of a bad PCM ground. Pull of the ground wire on the back side of the passenger side head. Clean it up and tighten it down. Also there is a ground with by the thermostat clean that up and retighten down.
See if this takes care of your problem if not then we will try something else.
So far no luck on the connections. All are clean and tight. I think my next step might be to disconnect the ECM and with the ignition switch off compare resistance readings on all of the inputs to the readings on the ECM inputs on my 94 chevy P/U. Then perhaps with the key sw in the ON position compare voltage readings on all of the inputs . They should all read the same.
The problem appears to be in a bad hot feed to the fuse panel. I have no power to just the left side of the fuse panel that contains the fuses for the ECM, Gauges, & Turn/Backup Lights. Now I have to figure out why.
Keep in mind the power feed wire to the fuse will only have power when the key is turned to the on/run position.
Yep, I'm aware of that. The circuit is dead in both the on/run and start postions. It looks like the fault is some where in the wire that runs from the fusible link locate under the hood, through the ignition switch, and then to the fuse panel.
Hopefully I'm getting closer to the problem.
Thanks
    • Uh yes, that's the name of the package. It doesn't quite bring it up to 1 ton specs unfortunately and imagine they have to do that for a numbers reason rather than a physical one.    Am I correct though that the Max Trailer Package and therefore the 12" rear is only available on the Duramax and not on any of the L8T 3/4 ton trucks ( and that the same 11.5 rear axle center section is used on the 3/4, 1 ton SRW and even 1 ton dually gas version ) ?   I'd also be curious to know if the wheel bearings are the same on a SRW configuration between an 11.5 vs the 12" diff as I assume parts would show that up but may not explain what the difference is if indeed there was a physical difference.
    • Why is gas up? Same reason the deficit is now $40 Trillion.
    • Mobil up another dime this am , $3.89, others will probably go up later. Any ideas on the reason for the increase other than greed? I've been working 14 hour days and haven't caught the news in a few days.
    • AMSOIL SS is about prevention and it is very good at it's job. I've never seen it claim to be a cleaner however like Valvoline R&P. Almost any oil that has some Ester or Alkylated Naphthalene in sufficient quantity will do a good job at keeping the rings functional.     I see the market splint among these types in two groups; those that use the same tech in every weight grade and those that reserve the tech for the EPA (EPA) friendly grades. Mobil 1 for example keeps the Advanced Clean chemistry out of the SAE 40 and up weights. Other like HPL (top shelf group and No-VII), Red Line HP, TORCO, MPT30K use the tech in all grades. Just not something the Wally World oils are into.
    • Max Trailering Package.  RPO code NHT.   includes 3500 HD Frame, 3500 HD Leaf Springs, 12" Rear axle and 3500 HD Shock Package.   GVWR goes to 11,750lbs for crew cab standard box 4x4, 11,900lbs for crew cab long box 4x4.  2WD crew standard is 11,500lbs, 11,550lbs crew long 2wd, and 11,450lbs on regular and double cab 4x4.       There is also NHT on 1 ton dually regular cab 2WD.  includes 3500 HD Frame, 3500 HD Leaf Springs, (F60) Heavy Duty Front Spring/Camper Package, 12" Rear axle, 3500 HD Shock Package, and Z6A Gooseneck / 5th Wheel Prep provisions with bed stamped holes and caps.  GVWR of 14,000lbs.
