Moving To Colorado
Greetings all,
I'm moving to Colorado the middle of next month. I went house hunting last week and while I was there I noted that gas is 85, 87 and 91 octane. Here in Virginia gas is 87, 89 and 92 octane. The owners manual states 87 is fine. I assumed that 87 was the lowest one could buy; I guess I was wrong. Does everyone in Colorado put 87 and shun the lower price 85?
If I use 85 will anything bad happen to the motor? I'm moving to Colorado Springs and the lower part of the city is over 6000 feet above sea level, will I need to get the PCM reprogrammed with a high altitude flavor?
thanks
I live in 'The Springs' and I've burned the 85 in everything I've driven, including my Audi A6. Currently driving a Sierra and an Acadia. Both run fine on 85. I moved here in '01 from Texas driving an Expedition and a Silverado Regular Cab. I made no adjustmetns to either car and they ran fine.
Engines have a barometric pressure sensor of some form...the lower octane will be fine and your truck will adjust fine.
JP
You will be just fine with the 85. 85 up here at 5000+ ft is 87 down at sea level, 87 is 91, and 91 can be 93.
I've used 85 for years and no problems at all. Even the dealerships here tell ya if the owners manual says 87, you are fine using 85 here in Colorado. Just get used to the smog additives they put in the fuel here and also keep in mind that the truck will seem a bit slower on acceleration compared to how it might be down at Sea Level.
Cheers
By "Moving to Colorado" I thought you meant you were moving to a Chevy Colorado instead of the full size. I was confused after I read your post, then realised you were moving to a different city, not a different truck.
:thumbs:
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
