Switch Wireing Help
ok i have my fogs installed i put a carling switch in dash. well its all wired it turns lights on but the led indcator on switch stays lit all the time , did i wire switch wrong switch on back has 2 prongs on one side one in middle and one on other side. fog lights have a ground and 2 power wires .
its a 3 postion switch i bleave because it gose from far right stops in middle and hen gose to far right . switch dident come with instructions . any help id apprecate.
So the switch has only two blades total? If so, usually the middle blade will go to your fog lights while the other blade goes to your power source. If it's a lighted switch, it should also have a blade for ground too, though.
