2005 Chevy Colorado
jmaggio2
i was starting brake job when i came across captured rotor. how to you remove wheel hub infront of rotor? i can get all off but the wheel hub so that i can replace rotor.
john
Good luck with that. I've yet to see someone replace one. GM pays 1.8 hours on 2wd and 2.7 on 4wd, it's pretty hard to beat warranty time first time out so for a 4wd your probably looking at 3.5 hours if you have all the tools you need. We use an on car lathe to turn those rotors. I'll look up the procedure for you though if you still want to try it.
yes if you could get me the info. if i can save money i feel it is always worth trying. i've done a lot of brakes jobs on my own. this is the first time i've seen captured rotors.
thank you,
john
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,373 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
