What does it mean on the suspension lift when i says no more than 4.5 back spacing? I have a +18 offset and the back spacing 5.71 on my new wheels could i get a lift with them? I seen that skyjacker had a 3in lift that allows stock wheels with it but says no more than 5in back spacing. I just want to run the real 33x12.50. Would it be easier to do a body lift? I just dont want my hitch to be moved down and have them bushings to pull it down, like i have seen. I would prefer a suspension, also what about the rancho lift? Or any others?
The reason is lifted spindles and control arms relocate the upper and lower ball joint in relation to the center hub. Wheels with factory like backspacing would hit the upper ball joint since it is moved. Less back spacing makes for clearance. When I installed the FabTech lift on my Silverado I had to go to different wheels at the same time. The factory wheels wouldn't even bolt up.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
