Some Gauges Work Intermittently
klanemfsu
I have a 1999 Chevy Z71 and on an intermitten basis when starting vehicle my gas gauge and temp gauge don't work, the message center flashes between low fuel, bad battery and security and my ABS light stays on. The next time I start it up, all of the above are working fine. What is causing these malfunction? Thanks.
it could be the cluster... does the speedo or tach stick at all?
Neither stick.. Can you expand on the cluster? Not sure where that is located.
I had the same thing hapen to me on my 2005 GMC Sierra. It turned out to be the main computer board behind the dash that controls everything (Cluster??) I found out that whoever installed the aftermarket radio used a hot wire from the computer board for power to the radio.... I guess this is a no no. Anyway, the board was replaced, the radio wiring was corrected and I haven't had a problem since. That was about $500 and 2 months ago.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,379 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
