Do You Love Your Truck?
Do you love your truck?
191 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hahaha, I'm sitting in my office and I was invited to my buddies cottage party in July. Then I realised how awesome my truck is going to be for that trip - just glad I've got a box for beer cases, another buddies atv, etc. Good Times!
Yes, I love this truck. I enjoy driving it and the power it has, and I especially like how it looks polished up and the sun is shining down on it. It is good to have a GMC.
I spent a week driving a 1999 RAV4 and couldn't wait to get my truck back. Funny thing is I have almost 36K miles on my '07 now and it felt like I was driving a brand new vehicle. No squeaks or rattles, steering still tight and smooth strong brakes. Really couldn't be happier.
I think the OP was just using this poll as a subtle way of finding a boyfriend. C'mon, come out of the closet, we won't bite....well, Scott (AlaskaLTZ) might, but the rest of us won't. :sigh:
Theres a "non-writen" rule on the forum,It goes like this....."Any forum member thats invited to a party MUST invite fellow forum members to attend" :(
Just when and where is this party so I can clear my schedule :crackup:
BTW...I do love my truck :sigh:
You think, I looked for a name to see if it was m or f but no name. :(
Just when and where is this party so I can clear my schedule :lol:
So, it's YOU that want's to be his boyfriend!!! Maybe you two should take this to PMs? :crackup:
Darn Bill,You do do some driving don't you? 36k already!! :sigh:
We got our trucks around the same time I think (Mid-March) and I'm cringing because I'll turn 12k next week on my trip to Charlotte for the NASCAR race :(
Oh well....You buy'em to drive right? :crackup:
Darn Bill,You do do some driving don't you? 36k already!! :(
We got our trucks around the same time I think (Mid-March) and I'm cringing because I'll turn 12k next week on my trip to Charlotte for the NASCAR race :crackup:
Oh well....You buy'em to drive right? :lol:
+1 I just rolled over 12K miles and I got mine on Mar 10th, 2007. :sigh:
Oh no...HELL NO!!!
I'm just lookin' for us to get invited to a party!! :lol::lol:
Theres a "non-writen" rule on the forum,It goes like this....."Any forum member thats invited to a party MUST invite fellow forum members to attend" :lol:
So, it's YOU that want's to be his boyfriend!!! Maybe you two should take this to PMs? :lol:
Oh no...HELL NO!!!
I'm just lookin' for us to get invited to a party!! :D:lol:
:crackup::(
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
