03' Z71 A/c Trouble
dirtywrench
Not sure were to start looking. If I set the fan setting on 1 0r 2 it well not blow air. 3,4 and 5 work fine. Could it be a relay or fuse?
Thanks
Dirtywrench
Yeah I had the same problem, it was the lower blower resistor. It was really easy to replace and cost $30+ dollars at the autoshop, stay away from the dealers, they wanted twice as much
Thanks alot
Where do I look to change this resistor?
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 897 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
