Rain Leak In Cab
Rick98Z
I have an 04' Chevy 2500LD crewcab 4x4. I had a rain leak in the drivers side front of the cab that has gotten worse. At first I thought it was coming down the pilar on the drivers side from maybe a windshield leak but now after ripping the dash even more apart it looks to be coming out of a rubber strip on a body seam, located to the far left behind the instrument cluster and vent line. Any thoughts? I don't want to have to go to the dealer for something so far back in the dash. Could it possibly be in from a leak in the cowl at the base of the windshield? I have heard that can be a problem area on our trucks from time to time. I have attached a picture to better show the actualy drip area...
It actually isn't a rubber strip, it is plastic and it wraps up over the metal...not sure what the fix is???
it is the seam at the top of the winshield post.pull out the black strip that goes up the winshield post on drivers side.look for seam where roof top overlaps post seal it with silicone.worked on my 04 2500hd to stop same leak.
Great I will give that a try!
I agree that it probably is the windshield seal. However, I would strongly recommend having the windshield professionally removed and installed as it plays a vital role in the structural integrity of the cab. If a portion of the seal is compromised, it should be properly repaired.
Oh and Awesome post. Pictures and all. Makes giving advice and help that much easier.
it is not the rubber seal.it is the seam under the seal where the roof metal overlaps the winshield post metal .there is a gap in the metal seam that needs sealed up.
Update: As per instructed I removed the black strip along the drivers side of the window. It has like 5 torx screws holding in on. Then I siliconed the area next to the top of the windshield where the roof seam overlaps the pillar seam. Checked it this morning in the rain and...dry floor! WOO HOO!!!! Thanks 1967 for your help and advice!
when mine leaked all over the floor the dealer couldnt find the leak.found it my self no more wet floor.glad to help you out.
Good job.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
