Operation Dumbo
Well I got the first one on, and I have to say that Member VT71's instructions are perfect. Thanks Clay!
I took a call from work and thought I would pound this post out...
Will post pics of the big ol' mirrors when I am done!!
I did mine without reading the instructions at all...Very simple, unbolt and unplug stock mirrors, bolt on new mirrors and plug in, check functions, seal everything up, adjust, and go.
Ranger I never said it was rocket science. Clay went to the trouble to type those instructions up, include them with the mirrors he sold me, and then he posted them for everybody that was asking about LTZ/SLT interior mirror installs. I am giving credit where credit is due, and let those guys know they will have no issues.
Great....can't wait to see em'.
Hope they help with that off-road "Alaska Package" camper of yours. I'm towing the boat this weekend for the first time with the small mirrors. I towed it earlier this year with your current mirrors and I must say, they serve their function quite well.
Those mirrors come in handy for towing a trailer. Don't forget to push them back in when your not towing. A buddy of mine forgot to, and peeled one of them off backing into his garage.
Looks great. I took the liberty of making you a new sig pic. I hope you don't mind. :(
Where are the clown wheels and the big red nose?
Here are a couple
Wow! You weren't kiddin' about Dumbo! Those things are huuuge!
And the dark one just looks cool :)
Actually, the dark one hides just how big those floppy ears are..! :lol:
I kid. I kid. The main thing is that they are functional, so y ou can see behind you and keep you & those around you safe. Nice job! :thumbs:
Looks great. I took the liberty of making you a new sig pic. I hope you don't mind. :thumbs:
:lol::):lol: That is awesome! I am going to use it!
Yeah, it kinda sucks...but with that trailer I had to do this.
:thumbs::lol::) That is awesome! I am going to use it!
I guess I missed it... What will you be pulling?
Pics of the whole setup (truck w/ new mirrors and the trailer attached) seem appropriate. :lol:
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
