Quadrasteer Swap
blucreek
I will be swapping a quadrasteer into my 2500HD.
I currently have 4.10 rear (Diff lock)
The truck is primarily used as a Welding rig, w/ the factory bed removed for a flatbed and 3k lbs w/ welding machine and tools.
Are all Quadrasteer rears limited slip?
Can I make the Q-steer pos. rear?
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,379 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
