New Complete Raido Install Kit
I just installed a new GM Factory nav unit in my new 2008 GMC Truck and will not need the following items afterall. I would like to sell everything as a package deal but will break up if I have to.
All items are new in mint condition,
(1) Metra GMOS-LAN-01 Wire harnes. This has everything you need for an aftermarket Nav unit. VSS wire and Reverse Wire
(1) Scosche Dash install kit
(1) Antenna Adapter
$150 OBO
Thanks!
Mike
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
