Adding Steering Wheel Audio Controls
It has been a while since I have seen a topic about this, and IIRC it is possible, but you need the clockspring. If you do a search for it you can know for sure, but I'm sure someone will chime in on this.
EDIT: What year is it? The easiest way to do this is to get one out of a wrecked truck and install it.
looking at getting a used 07. Already have one 07 that has it and I really like the feature.
Is that 07 Classic or 07 new body style?
Don
Sorry. Both are 07 NBS. Also interested in adding the full DIC functions. I know I have seen a post on this in the past but cant find it now. Thanks for the help.
Don
Click the DIC link in my sig for that answer. As for the radio controls question: http://www.gm-trucks.com/forums/index.php?showtopic=69054
Does anyone know if the DIC addon will work with an Regular cab SLE1 package? or did they only run the wires for the extended/crew cabs?
DIC worked fine in my regular cab NBS 07
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 750 Guests (See full list)
