Antilock Braking System
davecyr
I have a 2001 GMC Z-71 4x4. I changed the rear rotors and pads not too long ago and now when stopping it's like the ABS system thinks I'm on ice the last 20 feet or so and it activates. Very dangerous. I have experienced this on other GM vehicles when the sensors have gone bad in the front wheel bearings, but as far as I can determine there are no wheel bearing sensors or any other kind of sensor at the rear axle that I have found on my truck that could have been damaged from this brake cahnge. I have done my own brakes on this truck several times and have never had this happen. My ABS light is not displaying in the dash, but does activate when I pull the fuse so I know the light works. I do have a service engine light that is lit but I think the truck was built with it on so no change there. As far as I can tell nothing else has changed on the vehicle. Any suggestions you can offer would be helpfull. Thank you.
Document ID# 1587153
2001 Chevrolet Chevy K Silverado - 4WD
Subject: Product Safety - Front Wheel Speed Sensor Corrosion #04094 - (01/25/2005)
Models: 1999-2002 Chevrolet Silverado
2000-2002 Chevrolet Tahoe, Suburban
2002 Chevrolet Avalanche
1999-2002 GMC Sierra
2000-2002 GMC Yukon, Yukon XL
Located in Ontario, Quebec, Newfoundland, New Brunswick, Nova Scotia, Prince Edward Island
Condition
General Motors has decided that a defect which relates to motor vehicle safety exists in certain 1999-2002 Chevrolet Silverado, 2000-2002 Chevrolet Tahoe, Suburban, 2002 Chevrolet Avalanche, 1999-2002 GMC Sierra, 2000-2002 GMC Yukon, Yukon XL vehicles located in Ontario, Quebec, Newfoundland, New Brunswick, Nova Scotia, and Prince Edward Island. These vehicles may have a condition permitting corrosion to occur between the front hub/bearing assembly and the wheel speed sensor. If the brakes are applied while the vehicle is travelling at a speed of greater than 6 km/h (3.7 mph) but less than 16 km/h (10 mph), the corrosion may cause an unwanted anti-lock brake system (ABS) activation. If this condition occurred where stopping distance is limited, a crash could occur.
Correction
Dealers are to clean and treat the affected area, and in some cases, replace the front wheel speed sensor.
Vehicles Involved
Involved are certain 1999-2002 Chevrolet Silverado, 2000-2002 Chevrolet Tahoe, Suburban, 2002 Chevrolet Avalanche, 1999-2002 GMC Sierra, 2000-2002 GMC Yukon, Yukon XL vehicles located in Ontario, Quebec, Newfoundland, New Brunswick, Nova Scotia, and Prince Edward Island and built within these VIN breakpoints:
Year
Division
Model
From
Through
2002
Chevrolet
Avalanche
2G100036
2G363592
1999
Chevrolet
Silverado
X1100020
X1299247
XE100004
XE256732
XZ100011
XZ214525
2000
Chevrolet
Silverado
Y1100133
Y1405970
YE100163
YE433798
YZ100149
YZ371921
2001
Chevrolet
Silverado
11100142
11407113
1E100192
1E336884
1F106141
1F211164
1Z100191
1Z334358
2002
Chevrolet
Silverado
21100156
21419297
2E100444
2E305421
2F100374
2F240815
2Z100416
2Z348298
1999
GMC
Sierra
X1500012
X1571383
XE500003
XE555865
XZ500005
XZ540992
2000
GMC
Sierra
Y1100181
Y1403129
YE100251
YE433795
YZ100185
YZ371911
2001
GMC
Sierra
11100139
11407805
1E100214
1E336874
1F106143
1F211229
1Z100174
1Z335044
2002
GMC
Sierra
21100194
21419089
2E100809
2E305888
2F100538
2F241040
2Z101557
2Z348466
2000
Chevrolet
Suburban
YG100061
YG229022
YJ100468
YJ211389
2001
Chevrolet
Suburban
1G104020
1G280557
1J100301
1J292755
2002
Chevrolet
Suburban
2G126599
2G317898
2J101267
2J318178
2R232620
2R300009
2000
Chevrolet
Tahoe
YJ100026
YJ211859
2001
Chevrolet
Tahoe
1J100026
1J309634
1R100402
1R218091
2002
Chevrolet
Tahoe
2J100983
2J325817
2R116414
2R313418
2000
GMC
Yukon
YJ100166
YJ211823
2001
GMC
Yukon
1J103611
1J292565
1R100509
1R203664
2002
GMC
Yukon
2J184383
2J309025
2R116570
2R302224
2000
GMC
Yukon XL
YG100003
YG210566
YJ100393
YJ210566
2001
GMC
Yukon XL
1G101568
1G279527
1J101870
1J292644
2002
GMC
Yukon XL
2G127091
2G326479
2J100796
2J337991
2R232816
2R300196
Important: Dealers should confirm vehicle eligibility through GMVIS (GM Vehicle Inquiry System) before beginning recall repairs. [Not all vehicles within the above breakpoints may be involved.]
For dealers with involved vehicles, a Campaign Initiation Detail Report containing the complete Vehicle Identification Number, customer name and address data has been prepared and is being furnished to involved dealers. Dealers that have no involved vehicles currently assigned will not receive a report with the recall bulletin.
The Campaign Initiation Detail Report may contain customer names and addresses obtained from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any other purpose other than follow-up necessary to complete this recall is a violation of law in several states/provinces/countries. Accordingly, you are urged to limit the use of this report to the follow-up necessary to complete this program.
Parts Information
Parts required to complete this recall are to be obtained from General Motors Service Parts Operations (GMSPO). Please refer to your "involved vehicles listing" before ordering parts. Normal orders should be placed on a DRO=Daily Replenishment Order. In an emergency situation, parts should be ordered on a CSO=Customer Special Order.
Note: Very few vehicles will require front wheel speed sensor replacement; if required, order appropriate part from GMSPO.
Part Number
Description
Qty
89022218
Lubricant, Rust Penetrating (will service 50+ vehicles)
Lubricant, Wheel Bearing (will service 25+ vehicles)
Service Procedure
The following procedure provides instructions for repairing a corrosion condition where the front wheel speed sensor mounts on the front wheel bearing assembly.
Raise the vehicle on a suitable hoist and support as necessary.
Remove both front tires and wheels.
Compress the front brake caliper pistons.
3.1. Install a large C-clamp over the top of the caliper housing and against the back of the outboard pad.
3.2. Slowly tighten the C-clamp until the pistons are pushed completely into the caliper bores.
3.3. Remove the C-clamp from the caliper.
Important: It is not necessary to remove the front brake caliper from the bracket when removing the bracket in the next step.
Remove the two bolts that attach the front brake caliper mounting brackets to the knuckle.
Notice: Support the brake caliper with heavy mechanic's wire, or equivalent, whenever it is separated from its mount and the hydraulic flexible brake hose is still connected. Failure to support the caliper in this manner will cause the flexible brake hose to bear the weight of the caliper, which may cause damage to the brake hose and in turn may cause a brake fluid leak.
Remove the brake caliper and bracket as an assembly and support it with heavy mechanic's wire or equivalent. DO NOT disconnect the hydraulic brake flexible hose from the caliper.
Mark the relationship of the rotor to the bearing hub.
If equipped, remove the rotor retaining push nuts from the wheel studs.
Remove the rotor.
Remove the bolt (1) that attaches the wheel speed sensor to the bearing hub.
Notice: Carefully remove the sensor by pulling it straight out of the bore. DO NOT use a screwdriver or other device to try to pry the sensor out of the bore. Prying will cause the sensor body to break off in the bore.
Remove the wheel speed sensor from the bearing hub assembly.
Important: The mounting surface on the sensor must be flat in the next step in order to be mounted correctly on the bearing hub assembly. If the mounting surface on the sensor is warped or bent, the sensor must be replaced.
Inspect to see if the mounting surface on the sensor is flat. Check the mounting surface on the sensor head for flatness by placing it on the edge of a metal machinist's scale or other suitable straight edge to measure the flatness. Check the sensor for flatness in multiple positions/directions (minimum 3).
• If the sensor mounting surface is NOT flat (1), the sensor must be replaced. Proceed to the next step and replace the sensor.
• If the sensor mounting surface IS flat (2), the sensor IS to be reused. Proceed to Step 16.
Remove the wheel speed harness mounting clips from the knuckle (4) upper control arm (3) and frame (2).
Disconnect the wheel speed sensor electrical connector (1) from the vehicle wiring harness.
Connect the new wheel speed sensor harness electrical connector to the vehicle wiring harness.
Attach the wheel speed sensor harness to the frame, upper control arm, and the knuckle.
Temporarily plug the wheel speed sensor hole (1) in the bearing hub to prevent debris from entering it when you clean it.
Important: All rust and corrosion must be removed from the wheel speed sensor mounting surfaces on the bearing hub in the next step.
Using a wire brush, sandpaper, emery cloth, scotch brite, or equivalent, thoroughly clean the wheel speed sensor mounting surface (2) on the bearing hub to remove any rust of corrosion.
Using compressed air, remove all debris from the bearing hub surface.
Using a clean shop towel, clean the sensor and the O-ring.
Important: While the corrosion is drying in the next step, begin performing Steps 3-20 on the opposite side front wheel speed sensor.
Apply (spray) two thin coats of the specified rust penetrating lubricant (corrosion inhibitor) listed in this bulletin, to the complete sensor mounting surface on the bearing hub. Allow to dry for 3-5 minutes between coats.
When the corrosion inhibitor is dry to the touch (about 10 minutes), apply a light coating of the specified grease to the complete sensor mounting surface on the bearing hub and to the sensor and O-ring.
Remove the temporary plug from the hole in the bearing hub.
Install the wheel speed sensor in the bearing hub and install the bolt. Ensure that the sensor is seated flat against the hub.
Tighten
Tighten the wheel speed sensor mounting bolt to 18 N·m (13 lb ft).
Disconnect the front wheel speed sensor connector and place a digital volt meter (DVM) across the terminals of the wheel speed sensor connector. Rotate the bearing at approximately one revolution per second. The minimum reading should be at least 350 ACmVs. If the reading is less than 350 ACmVs, the wheel speed sensor must be replaced. Follow Steps 12-15 for instructions on replacing the wheel speed sensor. This step must be repeated after the new sensor has been installed.
Notice: Whenever the brake rotor has been separated from the wheel bearing flange, clean any rust or foreign material from the mating surface of the rotor and flange. Failure to do this may result in increased lateral runout of the rotor and brake.
Important: If the rotor was removed using the jack screw method, you must ensure that the hub flange is free of nicks or marks caused by this procedure. Remove all raised nicks or marks before installing the rotor.
Align the rotor to its original position on the hub and install the rotor.
Install the caliper and caliper mounting bracket assembly.
Perform the following procedure before installing the brake caliper bracket mounting bolts.
27.1. Remove all traces of the original adhesive patch.
27.2. Clean the threads of the bolt with brake parts cleaner, or the equivalent, and allow to dry.
27.3. Apply threadlocker to the threads of the bolts.
Install the caliper bracket mounting bolts.
Tighten the brake caliper mounting bracket mounting bolts to the specification listed below.
Tighten
• 1500 Series vehicles -- 175 N·m (129 lb ft)
• 2500 Series vehicles -- 300 N·m (221 lb ft)
Install the front tire and wheel assembly.
Tighten
Tighten the wheel nuts to 190 N·m (140 lb ft).
Complete Steps 21-30 on the opposite side front wheel speed sensor.
Lower the vehicle.
With the engine OFF, gradually apply the brake pedal to approximately 2/3 of its travel distance.
Slowly release the brake pedal.
Wait 15 seconds and repeat Steps 32-33 until a firm pedal is obtained. This will properly seat the brake caliper pistons and brake pads.
Customer Reimbursement - For Canada
Customer requests for reimbursement of previously paid repairs to correct the condition addressed in this bulletin are to be submitted by January 31, 2006.
All reasonable customer paid receipts should be considered for reimbursement. The amount to be reimbursed will be limited to the amount the repair would have cost if completed by an authorized General Motors dealer.
When a customer requests reimbursement, they must provide the following:
• Proof of ownership at time of repair.
• Original paid receipt confirming the amount of repair expense(s) that were not reimbursed, a description of the repair, and the person or entity performing the repair.
Claims for customer reimbursement on previously paid repairs are to be submitted as required by WINS.
Important: Refer to the GM Service Policies and Procedures Manual, section 1.6.2, for specific procedures regarding customer reimbursement verification.
Courtesy Transportation
The General Motors Courtesy Transportation program is intended to minimize customer inconvenience when a vehicle requires a repair that is covered by the New Vehicle Limited Warranty. The availability of courtesy transportation to customers whose vehicles are within the warranty coverage period and involved in a product recall is very important in maintaining customer satisfaction. Dealers are to ensure that these customers understand that shuttle service or some other form of courtesy transportation is available and will be provided at no charge. Dealers should refer to the General Motors Service Policies and Procedures Manual for Courtesy Transportation guidelines.
Claim Information
Submit a Product Recall Claim with the information indicated below:
Repair Performed
Part Count
Part No.
Parts Allow
CC-FC
Labour Op
Labour Hours
Net Item
Inspect Wheel Speed Sensor (Inc. Cleaning)
N/A
N/A
MA-96
V1256
0.8*
Add: Vehicles with 8-lug nut wheels
0.1
Inspect & Replace One or Both Wheel Speed Sensor (Inc. Cleaning)
1-2
MA-96
V1257
0.9*
Add: Vehicles with 8-Lug Nut Wheels
0.1
N/A
N/A
N/A
MA-96
N/A
Customer Reimbursement (Canadian & Export Dealers/US CAC)
N/A
N/A
N/A
MA-96
V1258
0.2
* -- For Recall Administrative Allowance, add 0.1 hours to the "Labour Hours".
** -- The "Parts Allowance" should be the sum total of the current GMSPO Dealer net price plus applicable Mark-Up for the front wheel speed sensor needed to complete the repair.
*** -- The amount identified in the "Net Item" column should represent the sum total of the current GMSPO Dealer net price plus applicable Mark-Up for the actual cost of lubricants needed to perform the required repairs, not to exceed $0.68.
**** -- Submit courtesy transportation using normal labor operations for courtesy transportation as indicated in the GM Service Policies and Procedures Manual.
***** -- The amount identified in the "Net Item" column should represent the actual dollar amount for courtesy transportation.
****** -- The amount identified in the "Net Item" column should represent the dollar amount reimbursed to the customer.
Refer to the General Motors WINS Claims Processing Manual for details on Product Recall Claim Submission.
Customer Notification
General Motors will notify customers of this recall on their vehicle (see copy of customer letter included with this bulletin).
Dealer Recall Responsibility -- All
All unsold new vehicles in dealers' possession and subject to this recall MUST be held and inspected/repaired per the service procedure of this recall bulletin BEFORE customers take possession of these vehicles.
Dealers are to service all vehicles subject to this recall at no charge to customers, regardless of mileage, age of vehicle, or ownership, from this time forward.
Customers who have recently purchased vehicles sold from your vehicle inventory, and for which there is no customer information indicated on the dealer listing, are to be contacted by the dealer. Arrangements are to be made to make the required correction according to the instructions contained in this bulletin. A copy of the customer letter is provided in this bulletin for your use in contacting customers. Recall follow-up cards should not be used for this purpose, since the customer may not as yet have received the notification letter.
In summary, whenever a vehicle subject to this recall enters your vehicle inventory, or is in your dealership for service in the future, please take the steps necessary to be sure the recall correction has been made before selling or releasing the vehicle.
January 2005
Dear General Motors Customer:
Your dealer will clean and treat the affected area, and in some cases, replace the front wheel speed sensor. This service will be performed for you at no charge.
You may be contacted by a dealer other than the dealer who sold or is currently servicing your vehicle. Please be advised that you may take your vehicle to the General Motors dealership of your choice to have the recall service work completed. Please contact your dealer as soon as possible to arrange a service date.
If parts are required, ask your dealer for details regarding their availability. If parts are not in stock, they can be ordered before scheduling your service date.
This letter identifies your vehicle. Presentation of this letter to your dealer will assist their Service personnel in completing the necessary correction to your vehicle in the shortest possible time.
If you have already paid for some or all of the cost to replace the front wheel speed sensor(s) due to corrosion, and you have not received reimbursement under a Vehicle Service Contract, you should contact your dealer to seek reimbursement. Please provide your dealer with your original paid receipts or invoices verifying the repair, the amount charged, proof of payment, the date of payment of those charges, and proof of ownership of the vehicle at the time of the repair. Your request for reimbursement, including the information and documents mentioned above, must be received by your dealer by January 31, 2006. Reimbursement may be limited to the amount the repair would have cost if completed by an authorized General Motors dealer.
We are sorry to cause you this inconvenience; however, we have taken this action in the interest of your safety and continued satisfaction with our products.
Customer Support Department
General Motors of Canada Limited
04094
my '99 NBS Sierra does the same thing occasionally. I just haven't taken the time to clean the sensors yet.
a pencil eraser is the best from what I've heard.
Thank you very much! Probably more coincidental than something I did then.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,002 Guests (See full list)
