07-07 Dmax Ppe Programmer
PPE standard model Tuner for 06-07 LLY and LBZ Duramax. has 4 power levels...40,90,160, and 225HP. It also can correct speedo for larger tires andread and clear DTC's. I am looking to get 400.00 and I'll cover the shipping
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
