Keyless Entry
donq
Is keyless entry available for my truck? (2007 Sierra new-body). I got a basic package without keyless entry and the dealer is telling me it is not possible... if i wanted it the cost was 1200$$. Is there another way to accomplish this? What about keyless start? It's got an electronic starter... basically touch it and it turns... no need to turn the wheel per se.
Thanks.
Dong, O Dong, where is my automobile? :uhoh:
Sorry couldn't resist. I would go with an aftermarket one unless it is possible to install a stock easily. But if you do go aftermarket, make sure you shop around and find the one you want and make sure its not an Avital (made by Directed Elec.), mine has a mind of its own. Sometimes the remote start and keyless work and most of the time it doesn't.
It should be possible to put the factory keyless entry on your truck. The question is, do you have power or manual locks? If you've got manual locks it's alot harder. Power locks, I believe you just need the reciever and the programming done so the truck recognizes it. Or you could go aftermarket. If you have manual locks, you would need to upgrade the whole truck to power locks, which is not impossible but will cost alot in parts and labor (unless you do it yourself). Remote start is likewise not impossible nor difficult, even without power locks.
I seem to remember reading that you had to have a remote start prep package or keyless entry prep package or something along those lines to be able to use the factory setup. If you truck doesn't have it, I'd suggest looking for an after-market product. Do some searches. There are several people on here who have installed after-market keyless entry and/or remote start.
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
